-   -   what kind of headers? (http://chevelleforum.net/showthread.php?t=2672)
whitey 04-06-2012 01:03 AM
Im about to drop a 454/475 HP BB in my 71' and was wondering what the best sounding headers and exhaust would be to get the real nice big block chop sound. any suggestions?
fleming23 04-06-2012 07:25 AM
Your cam is going to play a larger role in how it sounds than anything else. Headers will not drastically change your sound either (or not from one particular brand or size to another.) If you want a real choppy sound do a true dual exhaust with no X or H pipe and some sort of chambered muffler (aka Flowmaster, etc.) and turn downs just after the muffler.
As with anything performance related you typically have to make sacrifices for one thing to improve the other. Sound does not necessarily = performance. Flowmasters sound good but are restrictive compared to an XR-1, RacePro or Magnaflow style muffler.
My suggestion is for you to get a 3" mandrel bent system with a quality H or X pipe and a decent set of flow-through mufflers. This will give you the best of both worlds. The 3" exhaust will be generally louder than a 2.5" system, especially at WOT. The X pipe will give you better flow and will not restrict your horsepower. Most big blocks are going to sound good regardless unless you just have a super docile cam in the thing.
Just my opinion.
Regarding the headers, how much do you have budgeted? Some cost significantly more than others. I put Doug's D316 1 7/8" Headers on my 496 and they fit very snug but did not require any denting of tubes for clearance. There are other less expensive options that get generally good reviews such as Hedman. Hooker's have the tendency to hang lower than others so keep that in mind when making your final decision.
shadowgray396 04-06-2012 06:17 PM
Good info on headers.
Ms Grumpy 04-06-2012 06:59 PM
Good info Eric.
whitey 04-06-2012 11:56 PM
thanks for the info man. I dont really care how much the headers cost. i want to get the best quality i can.
RBeckman 04-08-2012 04:30 PM
I put the hedman's on my big block and could not be happier on the fit, finish...my buddy has hookers and they were more expensive and don't fit any where as nice as mine. Make sure you get the ceramic ones what ever you do choose.
fleming23 04-08-2012 06:53 PM
Doug's or Hedman Elites. You won't find too many negative comments about either. Just make sure you pick a size that fits your application. My personal recommendation is to do 1 7/8" over 2" both based on the power your motor makes (with my limited knowledge) and the tight clearances I experienced on my 1 7/8" Doug's.
If you want to spend some real money for headers that are supposed to fit like a glove take a look at Lemon's.
SS Shaun 04-08-2012 10:33 PM
man i was just about to ask this question because i am trying to get the camaro to 300hp now..lol
