Changeing manual to power steering
i have an ss 66 chevelle Has anyone changed over the manual to power steering, what are the correct parts that i need to be changed, the motor is a 72 -85 BB 454
Long or short water pump? Also welcome to the site.
Welcome to Chevelleforum .
Welcome. Sounds like a big undertaking.
Make sure you get the pitman arm with the steering box. They are different from PS to non-PS. And they are different from car to car. i.e. - camaro/nova will take a different arm than a Chevelle. The aftermarket parts suppliers have pretty much everything available - if buying new. If scrounging used parts, most sources list 64'-76' GM A-Body as the same steering box. The pitman arm is 65'-67' from what I have seen.
HTH |
| All times are GMT -5. The time now is 10:40 AM. |
