-   Chevelle General Talk (http://chevelleforum.net/forumdisplay.php?f=18)
-   -   My Chevelle shakes (http://chevelleforum.net/showthread.php?t=3378)
Jeff 67 02-13-2013 05:00 PM
My Chevelle shakes
Hi, I'm new to your Chevelle forum. I have a 1967 SS 4 speed 396 and when I go over 60 MPH my stick shift shakes, real bad. I need to slow down ,then things are ok again. I had the front end look at and all was ok. Could it be the drive shaft ? or maybe the clutch ? I need help. I just do not want to keep putting money into something that does not work .
Thank you Jeff 67:mad:
Ms Grumpy 02-13-2013 05:50 PM
Welcome Jeff. You ask if it could be a few different things. I think it might help if you give a little more information. What is new, used, or you don't know. I am sure you will get some help on solving your problem. Good Luck.
FlintTony 02-13-2013 06:45 PM
Jeff, the first thing that I would check is the bolts that mount the shifter to the mounting plate and the bolts for the mounting plate that go into the transmission.
Jeff 67 02-13-2013 08:42 PM
Hello thanks for getting back so fast to me. All the bolts on the shifter are good and tight. I just had the alignment done as well
fleming23 02-13-2013 09:02 PM
Is it any speed over 60 or if you speed up to say 65 or 70 does it stop?
When is the last time you checked or replaced the u-joints in the drive-shaft?
shadowgray396 02-13-2013 09:37 PM
X2, that would be my guess, or out of balance drive line
FlintTony 02-14-2013 06:05 AM
Is the shifter the only thing that vibrates or shakes? How is the trans mount? Tight and not broken?
Jeff 67 02-14-2013 02:55 PM
Hello,, my car starts to shake around 55 mph ,the faster I go the more it shakes. I have not check the u-joints, but it does not shake or vibrate under 55 mph. The faster I go the hole car starts to shake.
BillsCamino 02-14-2013 03:05 PM
Do you also feel vibration in your seat or at the steering wheel?
Could be something as simple as a tire out of balance...
If it's only at the shifter...have the u-joints replaced AND get the driveshaft re-balanced. A local driveshaft service shop here only charges $70 for all that.
Something I ALWAYS have done on any of my project cars.
While your under there pulling the shaft...take a good look at the tranny mount to be sure it's not unbolted, broken or the rubber aged.
carpoor 02-14-2013 03:31 PM
Be sure of the transmission mount. Some of these replacement mounts aren't 100% correct and can affect driveline angle just enough to throw things off. However, the driveshaft was my first thought when reading this. Then I wondered to myself weather or not you had a polyurethane transmission mount.
HTH
