68 Chevelle Pro Street Chassis Complete for 10 inch tire
UPDATE 2/21/14 NOT GOING TO CUT THE CHASSIS OUT GOING TO SELL THE CAR LESS BOLT ON SHEET METAL MEANING HAS A FULL INTERIOR NO DOORS,FRONT END,TRUCK DECK,REAR BUMPERS I have a Professional built complete bolt into your car GM Chassis that was garaged for over 35 years so its used and mint condition frame then 2 years ago I wanted to build a 8 second street car and wanted the best of the best your cars rear wheel tubs would need to be stretched inside your truck so 29.5x10.5 ET drag radials on a 10 inch rim fit without touching anything.
almost everything is Brand new. Strange 9 inch 35 spline,5/8 wheel studs.Strange steel pro case/Spool,4.30 Pro gears,C moly yoke 1350 joints,reinforced case then Powder coated.Strange C moly 3.5 driveshaft with C moly 1350 ends for turbo 400,Art Morrison ladder bar with adjustable rear coil overs,up front Global west tubular control arms,Moroso drag springs,Qa1 adjustable front shocks Cross member boxed out to accept a much larger oil pan but still using motor mounts and stock style tire rods and steering box that is there,Wilwood 4 wheel disc brakes with vented rotors,IDIDIT chrome /tilt steering post/removable wheel,Grant classic steering wheel with S/S steering shaft/U-joints.WELD Drag Star wheels with Mickey tires front SR radials 26tall,rears 29.5X10.5 ET drag radials. This is all Brand New and not used and built professional I have a picture of the car done so you will see how your car will sit with a BBC up front.This car has a aluminum 10 gallon fuel cell Powder coated with a fuel sensor to work with our stock gauge a complete product engineering 460 fuel system with return system front and back to handle all your fuel needs.$15,000 will own it! Body/Chassis/Floors mint even has original rear back seat still in the car !!!! Any questions Mike 917 767 3549 ALSO Plenty of pics in my profile to see |
| All times are GMT -5. The time now is 10:54 PM. |
