rear brake problem
Just replaced the single bowl master cylinder on my 66 Chevelle with a double bowl and power booster for drum/drum brakes.Also replaced the distribution block at the frame.( All this came as a 'kit'). having trouble getting brake pressure to rear brakes. Have fluid at both cylinders but when pedal is pushed,no brakes. Front brakes are locking up but pedal almost goes to the floor. Any suggestions please. Thanks Dan...
Bleed the back brakes. Sounds like there is alot of air. In the master cylinder even still.
Did you bench bleed the master cylinder before you installed it?
Thanks for the reply. We bled the mc and rear brakes,but we will try again...Dan
disc brake conversion Help.......Master wont bleed out the rear... bench bleed ok, installed on car and hard pedal even when line is completely off. moved pedal rod to lower hole, still no difference. Any body have this happen...
1966 chevelle |
| All times are GMT -5. The time now is 09:24 PM. |
