Old 10-18-2010, 07:55 AM
Warputer's Avatar
Warputer Warputer is offline
Default Gas leak from vent...
It only happens when she is 3/4 to full and the car is parked with the front down a hill. From what I can feel.....(can't see without dropping the tank)....there are 2 vents on the top front passenger side of the tank & this is where there is a drip. As I said....with 1/2 a tank or less, it does not leak.
I'm guessing one of the 2 hoses are probably dry rotted or the vent tube is cracked. Anyone else had this issue? I plan to drop the tank tonight & I'll let you guys know what I find.
Chris
69 4-Door Malibu
Old 10-20-2010, 06:38 AM
Warputer's Avatar
Replaced both of the vent lines yesterday....the 3/8" line had a big blister on it, where it connects to the tank & the hose clamp was gone. The 1/4" line had a slit in it, at the lowest point......this explains the gas leak when the tank was full, especially when parked on a hill. I also added more length to the hoses, so the point that where they are open to vent, would be higher than the tank itself......gravity is very un-forgiving.
I'm just glad it wasn't the O-ring on the sending unit.....I really didn't want to drop the tank.
Chris
69 4-Door Malibu
Old 10-20-2010, 08:38 AM
Glad you found the problem and it wasn't a major repair. Thanks for letting us know what you found.
