Old 06-12-2012, 12:17 AM
dub dub is offline
Default Valve adjustment with large cam
Hello all,
I have a decent cam in my stroked 350, I was doing a valve adjustment and thought that I cant do a "standard" adjustment due to the cam being larger then stock, is there a different process then a stock cam?
Thanks,
Mike
Old 06-12-2012, 10:02 PM
What kind of camshaft? Hyd FT? SFT? Hyd roller? Solid roller? It shouldn't be any different unless you put a tight lash style cam in it. (Usually a Solid roller) Then it would just require less lash as the name implies. I would contact the camshaft manufacturer and see what they recommend.
