Old 10-18-2012, 01:11 PM
Default cooling system (fan question)
so a friend of mine came on the house a few weeks ago and he gave me a list of things i needed to complete before i can start my car. i am on the second to last thing on his list and thats the fan. I was going to put in an e-fan but after talking to my uncle and another car guy friend of mine they both told me forget the e fan and run a fan off your water pump. here are the reasons given to me
1) e-fan draws a lot of amps at start up of the fan.
2) I would need to get a high amp alternator
3) they can fail on you much quicker then a manual fan
so after talking to another chevelle owner he told me to get a fan with a fan clutch and set it and forget it. so i ask you guys what fan should i look for and what fan clutch should i look for? and do you agree on the three things stated to me about using E-fans
Old 10-18-2012, 02:51 PM
A factory type setup, fan, clutch and shroud will do the job. Yes you'd probably need a new alt along with relays to power the fans and temp sensors to turn them on and off.
Not sure what fan was stock on a 69 big block. 70's used a GM xxxxx772, don't have the full GM # handy but everyone refers to them as 772's. Along with a Hayden hd clutch and stock shroud will keep your engine running cool if the rad, water pump, etc are all good.
Old 10-18-2012, 03:31 PM
The fan blade you want is a 3947772, and the clutch you'll want to use is a Hayden part # 2747 HD unit. It will will run nice and cool, plus damn near last forever.
Old 10-18-2012, 06:04 PM
Thanks, didn't have the numbers handy.
You can find the 772 fan on ebay. If you don't care about date codes they're not too expensive, mine is a 1973 fan. I replaced a flex fan with a 772 and the Hayden 2747 clutch.
Old 10-18-2012, 06:45 PM
Just purchased both for my heap, so it was fresh in my mind.
