Old 03-21-2016, 06:56 PM
Default Speedometer Cable?
The car didn't have a cable from the speedometer when I bought it. I'm not sure where it should run through the firewall. Took some pictures of likely areas.
There's a fairly large diameter hole behind the brake pedal:
There's a small hole in the center of the firewall:
And there's an access below the throttle cable:
Can anyone help out?
Old 03-22-2016, 06:46 AM
Your pictures are too small to really see anything. I'll take a look at mine this morning and let you know.
Old 03-22-2016, 08:09 AM
I think it depends on what model it is sometimes. Mine is the one behind the brake.
Old 03-22-2016, 09:47 AM
Mine, a 70, comes out almost directly below steering column. Just below where firewall curves back into floor pan. Goes through a plastic/rubber grommet that pops into sheet metal.
Old 03-22-2016, 07:00 PM
That's the one behind the brake. Sorry about the pictures, they looked fine in my gallery but showed up small in the post.
Old 03-23-2016, 06:49 AM
My car is covered so I only looked under the hood, not inside. I believe there is a plastic kick plate at the top of the carpet that the cable passes through.
