Old 06-21-2021, 12:29 AM
RogerB RogerB is offline
Default Engine swap
I am looking for some pictures of the engine stands on a Chevelle frame. I have a 1971 Olds Cutlass that i`m putting a Chev 350 LT1into and was told that they are the same frames. Thanks for any help.
Old 06-21-2021, 08:17 AM
Old 06-21-2021, 10:22 AM
Great picture but will the block header hit the frame? Thanks
Old 06-24-2021, 07:04 AM
Guy who works for the engine builder has a 69 chevelle. He has them on his 396. That is why I got them.
Old 07-04-2021, 07:16 AM
As if things were not going slow enough. My engine builders dyno caught the building on fire and burned half the shop down.
On the lighter side he decided I wanted a different cam. 2 degrees more @50 on the intake and centerline moved from 112 to 110. I was there he said oh there is your new cam.
I instantly went through the PIA of entering everything in desktop dyno. 30 more HP and a flatter torque curve. Moved the peak up to 6 grand.
My engine and parts were in the part that did not burn thank you. And he will finish it he said. I was there when the insurance adjusted came. Now the clean up and rebuild on the building can begin.
Old 07-28-2021, 08:16 PM
just got a cool case radiator and shroud and fans. Bunch of knick nack stuff. He said mine is next in line for completion.
Old 08-23-2021, 06:25 AM
Well after the fire and delays it is finally about ready. he is waiting on a timing cover and a few other things. But he said last week I should have it this week if everything goes well. Motor is finished tho. Carb is on he needs to put the distributor in.
