Old 09-11-2020, 09:37 PM
67-ls1 67-ls1 is offline
Default For sale - for sale - for sale - for sale
In 1997 I bought a 67 Chevelle convertible to use as my daily driver. Sold my Ford Ranger and went full Chevelle. In early 98 I came across an almost new but wrecked 1998 Camaro with an LS1-4L60e and without even thinking I bought it and started the swap.
At that time there were zero parts available for this swap. I would call people and they would say it couldn’t be done. I knew it could because a saw a 55 Chevy in a magazine that had an LS1 and then saw an early Impala bubble top with one at a Goodguys show.
It took me about 8 months to get it done but everything worked great. I drove that car almost 100k over the next 5 years. I sold it in 2004.
So when I got the itch again, I decided to do a 66 Chevelle and go for max mpg. I started looking around for an engine and again found an almost new Camaro (2013) with a 3.6 liter V6 and a 6 speed auto. It was wrecked with 525 miles. The project was on.
Here are a few pics of the beginning.
Out with the old engine/trans.
The new engine as it arrived.
First attempt at fitting it in.
ID:	4489   Click image for larger version
ID:	4490   Click image for larger version
ID:	4491   Click image for larger version
ID:	4492   Click image for larger version
Old 09-11-2020, 09:57 PM
Once it was determined that the engine wasn’t going to slide in I decided to remove the body and do the entire chassis.
I ended up cutting and boxing the front crossmember to clear the oil pan.
Then I had to build motor mounts. How many of you knew that the front crossmember mounting surfaces were 90 degrees from one another?
ID:	4494   Click image for larger version
ID:	4495   Click image for larger version
ID:	4496   Click image for larger version
ID:	4506   Click image for larger version
Old 09-11-2020, 10:11 PM
As it turned out, the sides of the LFX V6 are perfectly parallel to one another. So I built a wood box the same width to start with the motor mount fabrication. Way easier than swinging the engine in and out a hundred times.
This pic is of the engine box mounted to the Camaro sub frame with the Camaro mounts. This way I knew it was correct.
I built the engine side plates out of wood and then transferred it to steel.
I tacked them together than pulled them for finish welding.
ID:	4497   Click image for larger version
ID:	4498   Click image for larger version
ID:	4499   Click image for larger version
Old 09-11-2020, 10:23 PM
Loading up the frame to take it to be powdercoated.
The frame came back and was ready to assemble.
Full stage 4 Hotchkis suspension, front and rear.
Wilwood discs front and rear.
ID:	4501   Click image for larger version
ID:	4502   Click image for larger version
ID:	4503   Click image for larger version
ID:	4504   Click image for larger version
Old 09-12-2020, 01:35 AM
Having the body off made it easy to set the engine/trans. I was also able to run the brake and fuel lines. Also added the 17x8 and 18x9.5 rims and tires.
The exhaust down pipes (Manifolds are built in to the heads) from the Camaro lined up perfect with the humps in the stock Chevelle crossmember. Pure luck.
ID:	4508   Click image for larger version
ID:	4509   Click image for larger version
ID:	4510   Click image for larger version
ID:	4511   Click image for larger version
Old 09-12-2020, 11:50 AM
To set the body back down I had to enlarge the transmission tunnel. The new trans is huge and mounted a little higher for ground clearance and the proper driveshaft angle.
ID:	4513   Click image for larger version
ID:	4514   Click image for larger version
ID:	4515   Click image for larger version
ID:	4516   Click image for larger version
Old 09-17-2020, 07:52 PM
Once the body was back on the frame I could start with the wiring. LOTS of wiring. I bought rolls of wire color and stripe combos to match the factory harness.
ID:	4519   Click image for larger version
ID:	4520   Click image for larger version
ID:	4521   Click image for larger version
ID:	4522   Click image for larger version
Old 09-17-2020, 08:00 PM
I used a Wilwood master for manual brakes.
I wanted the stock Powerglide shifter so I had to make a new detent plate that matched the required throw of the 6L50e transmission.
Mock up of a power steering line.
ID:	4524   Click image for larger version
ID:	4525   Click image for larger version
ID:	4526   Click image for larger version
ID:	4527   Click image for larger version
Old 09-17-2020, 08:10 PM
I had to realign the upper water neck. It was aimed down in the Camaro
The drive shaft now has a CV joint on the front because the trans has no slip yoke.
The trans cooler lines from the Camaro cleared everything. I just needed to extend them a little to reach the trans cooler in front of the radiator.
New steering wheel and Dynamat.
Notice, no gauges in the dash...
ID:	4529   Click image for larger version
ID:	4530   Click image for larger version
ID:	4531   Click image for larger version
ID:	4532   Click image for larger version
Old 09-17-2020, 11:53 PM
Dash board without any gauges, ash tray or a glove box.
The next owner (grandson) asking “what this is for Papa?”
I did a complete color change on the interior from black to red.
New ProCar seats.
Painted seat tracks to blend in more with the carpet.
Registration back on after 20 years off the road!!
ID:	4534   Click image for larger version
ID:	4535   Click image for larger version
ID:	4536   Click image for larger version
ID:	4537   Click image for larger version
