Old 02-06-2011, 09:32 AM
69 Post Sedan's Avatar
69 Post Sedan 69 Post Sedan is offline
Default Big & Small Block Chevy Parts + Aftermarket Parts
I have a 1970 402 CE warranty 4 bolt main block for sale. The casting number is 3969854 block cast H.30.9 (August 30, 1969).
What makes this block so rare is that it has two stamps. It was originally stamped T0916KE. T=Tonawanda, 09=September, 16=sixteen day and KE is a 1969 Camaro with a 396/375hp L89 Aluminum head motor with a RPO MA6 dual disk clutch. Chevrolet ended up NEVER building a 1969 Camaro with dual disk clutch. This block was then changed to a CE block at Tonawanda. It also has T099 (Sept. 1969) stamped down by the starter bolt holes.
It’s currently bored .040 over. The cylinder walls are a little on the big side. As with any used block it should be align honed. This block has been inspected for cracks and has been sonic checked. $1700
I have four (4) used 6272990 big block Chevy rectangular port open chamber heads for sale. Both are complete with valves, 3/8" guide plates and 7/16" rocker studs. No porting whatsoever. These heads are service replacement heads and are the same as the 14096188 heads.
(2) 2.19/1.88 Stock valves. $500pr.
(2) 2.25/1.88 Manley valves. $500pr.
336781 open chamber oval port heads. These heads are bare. (Casting dates from 1973-1978) $50 each
343772 open chamber oval port heads. (Casting date B.27.78, B.28.78) $100 pr.
346236 open chamber oval port head. $50 (casting date F.16.79)
1969 closed chamber oval port heads (2). (Bare) Casting number 3931063 dated A.23.9. These heads have been cleaned and pressures tested and are guaranteed. These are correct for 396/427 1969 Chevelle, Camaro, Nova, Corvette and Full-Size cars. 100.9cc $300 pr.
3993820 open chamber heads. They are correct for 1971 402 & 454 Big Block Chevy Corvette, Chevelle, Monte Carlo and Full-Size cars. 113 cc. $75 each
3/8” BBC thumb rods. (8 used) $40
(7) 396 used +.060 Pistons with dome. $40
Used stamped steel BBC rocker arms with nuts and balls. $1 each
Very hard to find original GM 4.88 12 Bolt Gears. Part numbers: Ring 3862516, Pinion 3862528 This is for the ring and pinion only. $200
454 flexplate.(1) $25
454 harmonic balancer. $40
Stock BBC stamped steel valve covers $20
1970 and newer lower alternator bracket. NOS $20
Complete set of head bolts w/”M” $40
Complete set of random head bolts. $20
Complete set of timing cover bolts with ”L”. $20
Complete set of random timing cover bolts. $10
(3) Small Block Chevy points distributors. $20 each
Vintage Lakewood Leaf Spring Traction Bars For Camaro/Nova. $50
GM alternators. 1100843 61 Amp. Dated 1C31, 1103076 64 Amp. Dated 8J27. $20 each
Rear quarter glass tinted for 300 Deluxe Post Sedan. Came out of a 1969. $40 pair
Thanks, Kurt
Old 02-08-2011, 10:51 AM
robo3's Avatar
robo3 robo3 is offline
pm sent for 1970 & up lower alternator bracket. NOS $20
Old 02-08-2011, 05:29 PM
PM sent....sorry for the confusion!
Old 02-14-2011, 09:01 AM
jsulen jsulen is offline
I'll bookmark this page first coz my friend is looking for some chevy parts. I hope you have the parts that he is looking for.
Old 02-14-2011, 09:27 AM
Me too!
I just aquired a few sets of 336781 BBC Heads. They will need to be rebuilt but are complete with 3/8" guide plates, 7/16" rocker studs and valves.
I'm selling them at $150 a set.
Kurt
Old 02-14-2011, 03:05 PM
Wish you were closer...I'd like to have an extra pair of -781s on hand, I've already got a brand new set of Manley Street Flo 2.19/1.88" stainless valves and Isky 8005 springs but shipping is the deal killer.
Old 02-14-2011, 04:26 PM
Bill, the last time I shipped a pair it was to Ohio and it was about $60 if I recall.
Kurt
Old 02-14-2011, 06:17 PM
Probably more now...FedEx/UPS both raised rates the 1st of the year...offset fuel costs, I guess.
Let me think about this...
336781 open chamber oval port heads (bare). (2) 113cc $75
Actually just noticed, the bare -781 heads with the 113cc chambers you have would work too.
I'm
Old 04-02-2011, 10:23 AM
UPDATED
Thanks, Kurt
Old 04-28-2011, 11:37 AM
Updated again.
Kurt
