Old 08-25-2014, 12:26 PM
Default engine oil??
Ok so when i rebuilt my motor i had a friend of mine tell me i should run 20w-50 in my 454. I have not had any issues as far as oil goes my pressure stays while nice and warm about 27psi at idle. I had good bearing clearance with no issues. I want to change the oil on the 454 this week since its been a few months i was thinking about going to 15w-40 since its getting cooler out now what do you guys think? Also should i add a bottle of zinc to my setup since i have a flat tappet cam?
Old 08-25-2014, 03:24 PM
Mobile 1 Synthetic 10W40 is a great oil. Over at TC a guy did a complete oil breakdown of every oil out there and this one out shines all the rest.
Old 08-25-2014, 08:42 PM
do you have a link for that by any chance? also with the mobile 1 did you need to add zinc?
Old 08-26-2014, 10:07 AM
No, you don't need to add anything. Here is the link for the info on different oils. You'll notice in his 2nd post there are 2 oils above the Mobile 1 one. The first one he cant find any data to back it up and the second one is for racing only. Above I told you 10W40 when it should've been 5W30.
http://www.chevelles.com/forums/show...nt+engine+oils
Old 08-26-2014, 11:48 AM
Valvoline silver bottle conventional oil. Full of minerals that will help protect the camshaft and bearings.
Old 08-26-2014, 02:04 PM
Carpoor, that's basically a racing oil and not recommended for street use.
Old 08-26-2014, 05:03 PM
Depends on who you ask. I use it with no issues. I am not a fan of synthetics in BBCs, too thin IMHO.
Old 08-27-2014, 07:16 AM
A thinner oil isn't necessarily bad. People often think a thicker oil is better because it raises the oil pressure. True but the down side is it reduces oil flow. Thicker oil raises oil pressure because it can't flow as easily through all the places it needs to go. If high oil pressure is your goal go with something really thick. Oil pressure will go through the roof but your engine will suffer due to lack of lubrication.
A thinner oil flows easier so you're moving more oil through the system which helps with cooling and filtering of the oil.
Old 08-27-2014, 11:18 AM
Castrol 20/50 or w30. With some zinc additive.
Its nice and warm in florida so I don't need a low visc oil.
Old 08-27-2014, 02:42 PM
I run 15-40W synthetic in everything i own. It looks better coming out than some of the Pee-water some of my customer put in. I actually put my used vans motor oil in a customers rebuilt engine because the garbage they brought me was terrible. If it going to have a shot at breaking in it needed actual oil in there. I would rather it throw a rod after they work on it, than before.
