Old 10-23-2011, 10:31 PM
mprat mprat is offline
Default Motor Identification big block ss
I have a 67 Chevell SS with a 396 engine with no numbers on it to tell what year it is, cannot find any numbers on the front pad, they are wore off. Any other way to tell if this a 67 engine or ???? I have the engine taken apart,,, thanks
Old 10-23-2011, 11:22 PM
rmvela626 rmvela626 is offline
what about the engine casting code on the driver side rear? (raised numbers, should start with a 3) Also look for a code on the passenger side, side of the block, just above the oil pan. Is it a 2 or 4 bolt main? And lastly, if you suspect the cylinder heads are the original or stock off the engine, what's the casting number? (also raised numbers, should start with a 3) Then go check out this site http://www.roadsters.com/bbc/#blocks
Old 10-24-2011, 12:43 AM
Thanks it is a 3902406 shows 1967 is a 2 bolt main head casting 3931068 67 to 69 had some nice trw pistons L2240N-060 small bump on top, don't know if forged or not and cam number I can't find,, 390327 and 115887 and a noisey gear drive that had to come out,,,,
