Old 02-24-2013, 01:04 PM
John's Avatar
John John is offline
Default Crank Bolt removal
Any tips out there for removing the crank bolt? I am replacing the pulley and the center bolt won't budge without turning the motor. I'd rather not use the starter bump method. Any suggestion for blocking the flywheel? Vice grips? Otherwise I assume a impact wrench does well.
Old 02-24-2013, 01:38 PM
I can usually knock them loose with a quick shot to the breaker bar. If not, I have an electric impact that makes quick work of anything I can't budge by hand.
Old 02-24-2013, 08:00 PM
X2 on that, is the motor in the car?
Old 02-25-2013, 11:25 AM
John's Avatar
couple wacks on the breaker bar did the job. Thanks!
Old 02-25-2013, 11:19 PM
Glad to hear it worked out for you.
