Old 01-01-2021, 02:06 PM
Retired Retired is offline
Default Turn signal question
I have LED turn signals, I have the proper low load part in the fuse block and my problem is that the right turn signal is a "bright....dim...bright...dim" when it is blinking. It does not go completely out between blinks.
The LEFT, however, acts properly. Weird.... I am thinking maybe a ground wire is loose or disconnected? I replaced the signal part in the fuse block but it did not change anything...
Any thoughts?
Thanks in advance for thinking those thoughts....
