Old 11-07-2021, 09:44 PM
Malibukid71 Malibukid71 is offline
Default Reinstall of AC...am I missing anything?
I have a 1971 Chevelle with a 1981 350 small block from a pickup in it. Before I got the car 20 years ago the AC had been removed. I'm finally able to work on the car and recently picked up what I'm told is a complete AC system for a 71. The guy had removed it all (working at the time) from his car to put in a Vintage Air system. My plan is to install the AC as I slowly replace most of the front clip of my car. I just don't know if I'm missing any pieces. The factory box is still installed on the firewall (don't mind all the rust...keeps falling out of the way gone hood), I see I have the condenser, compressor, and what I believe to be the drier, along with a bunch of tubes & hoses. Does it look like I'm missing anything? I'm hoping once I get the front clip back in shape I'm able to just take it somewhere to get it charged.
ID:	4750   Click image for larger version
ID:	4751   Click image for larger version
ID:	4752   Click image for larger version
Old 11-08-2021, 07:18 PM
There a plastic diverter on the floor vent. I would advise getting the r-134 retrofit switch with high and low pressure switches. Keeps the compressor from working if something is wrong. Burning up compressors. You can still run r-12 but this kit just lets you have pressure switches. Which they didn't have in those years.
Old 11-08-2021, 08:55 PM
The original should still be in the car as it looks like only the quick and easy things were removed. I may have to look into that upgraded diverter though, I think I've seen those on a few sites.
Old 11-09-2021, 06:20 PM
https://coldhose.com/products/r134a-...35532366119072
