Old 06-30-2010, 08:33 PM
136ED 136ED is offline
Default pulleys
i need to buy new pulleys for a 350 i purchased, the problem is it has an electric water pump. i have no clue what pulleys to buy. every thing i found has a water pump pulley. what is it i need to buy, what are they called?
Old 06-30-2010, 08:47 PM
I would stick with the stock double pulley on the crank. Then it's just a matter of finding the correct length belt for alternator. The power steering belt would remain the same.
Old 06-30-2010, 09:19 PM
will the alternator from a 307 work on a 350 as well? will the power steering belt work on the new motor also?
Old 06-30-2010, 11:34 PM
Rattler's Avatar
Rattler Rattler is offline
With an electric water pump you will need to mount your alternator low to make it work. What accessories are you running off the motor?
Old 07-01-2010, 06:36 AM
well I have an electric water pump and I'm getting an electric fan so I guess just the power steering and the alternator. I'm not really sure. This is the first time I'm doing all this stuff.this is my first project.
Old 07-01-2010, 01:30 PM
Rattler's Avatar
I ended up using a low driver side alternator mount and just flipped it to use it on the passenger side. I'm running an electric fuel pump so I had the room. With a mechanical fuel pump I don't believe it would work. I'm not sure what groove the power steering rides on in your car. Does everything ride on a single belt or does the steering have a separate belt? You may be better off just removing the electric pump and installing a normal water pump. Especially if this is going to be a daily driver type vehicle.
Here's a pic of mine down low on the passenger side.
