Old 08-16-2010, 03:41 PM
Cool For Sale: Fresh big block 454 +.060" BBC-complete from carb to pan
I had this engine built to install in my '67 Malibu for a while until I completed my LSx conversion quest but I've changed my mind and now offer it for sale here.
Here are the engine specs...
Fresh 454 + .060" 468 BBC short block
’70 dated -512 casting ARP studded 2 bolt block
balanced assembly which includes a cast GM crank, rebuilt (thumb print) GM rods, and TRW 2399 + .060” 13.8cc forged pistons
All completely assembled using King bearings and Perfect Circle rings.
The block does have one sleeve (#8) which was professionally installed and has just been pressure tested OK
Fresh pair of ’74 dated -781 GM casting oval port heads
completely redone with brand new 2.19”/1.88” Manley stainless valves, hardened seats, Comp Cam 924 springs, ARP head bolts
GMPP oval port, square flanged aluminum intake (same as Eddy RPM intake)
Fresh rebuilt Holley 750 double pumper carb
Comp Cam "Thumpr" flat tappet hyd cam and Comp lifters
Cam specs are 279/296; 227/241 @ .050”; .498/.483”; LSA 107 with ICL of 102
New CompCam timing set and Comp Magnum 1.7 ratio rockers
Milodon 6qt kickout oil pan with Mellings HV pump and matching Milodon pickup
Stock harmonic balancer and timing cover,
14” flywheel OR a 14” flexplate (your choice).
Chrome valve covers with drippers
Mallory HEI distributor
This block was zero decked. FelPro 8180 gasket kit was used...head gaskets are .039" thick with a 4.370" bore. The heads chambers cc'd at 108.
The CR is approx 10.2 and will run fine on pump premium gas.
This engine was just completely rebuilt and assembled by Walker Performance in Hiram, GA.
Complete from carb to pan...Ready to drop in and run in your street rod or muscle car.
Will sell for $3500 or BO or trade???
Old 08-16-2010, 08:54 PM
How come these deals come up AFTER I'm in the market? Good luck with the sale Bill.
Old 08-18-2010, 09:21 PM
I totally agree..
Old 08-18-2010, 09:42 PM
I can trade a Pacificia if you would like. Just tell me how much cash you are willing to give me.
Old 08-18-2010, 02:26 PM
smokenjoep01's Avatar
I am VERY interested. Please tell me your interested in a motorcycle to trade? Here is some info I had just posted on another site.http://www.horsepowerjunkies.com/for...d.php?t=104737
I HATE RUST!
Old 08-18-2010, 03:16 PM
Thanks Hank!
Joe,
PM returned...
Pics can't be viewed unless I register/login on that site.
Old 08-18-2010, 03:39 PM
Pictures!
As you can see by the photos that I had every peice powder coated. Wheels are laced with super size stainless spokes and nipples. Refreshed all bearings seals and gaskets in motor. Fresh hone, new pistons and rings and full valve job. Every part is new. on the bike. I did this 2 seasons ago. This is one of five bikes I have, so it has very low use.
I HATE RUST!
Old 08-18-2010, 04:01 PM
Let me show these pics to a buddy of mine who is way more into bikes than I am.
What engine is that? Chassis model year? Does this have a title?
Old 08-18-2010, 04:13 PM
1977 Yamaha XS650 Clean NC title in hand. The frame is custom built to my specs by a friend that fabricates at Redneck engineering in Liberty SC The very special features of this bike are the threaded rod end rear axle adjusters and the frenched in sight glass fuel gauge on the tank, that has been flat bottomed with a nice smooth arch. Hammered side panels done perfect. Most the bolt on parts are custom hand fabricated, tig welded.
I HATE RUST!
Old 08-19-2010, 07:14 AM
Czeto Czeto is offline
A bike in pieces in the dining room. Does your wife have a sister?
