Deleting account
Before anyone can give even a ballpark number, some things must be factored in. Compression ratio, valve size, flow numbers for the aluminum heads, camshaft profile, which exhaust system will be installed. Will it be a stock stroke crankshaft?
Wow, 17K original miles? What's the backstory on your car? Sounds interesting. Good luck with the build! |
This is the one I bought for my folk's car...
https://www.summitracing.com/parts/sne-550-516 The engine is a .040" over ATK 454, .100" dome pistons, hyd roller, fully CNC'd AFR 265s. The system I bought says good to 650 HP, will be more than adequate for their 454. I estimate their engine around 550-575 @ the flywheel.
Neat story Hubert. Sounds like it should be rust free. A big bonus for you.
I had an L78, 69 Chevelle with an all original driveline. The factory rated it at 375 HP. It actually "felt" like it had more HP than that. I compare that feel to the cars that I have now. Both Chevies have 427s in them One dynoed at 450 and the other one is a hair over 500. A pretty decent build for you to consider would be something along those lines. You would have to drop the compression ratio a little to run on the shit gas that we have now. |
Someday, I would really like to pull the LS5 out of my 72 and stick it on a dyno. Most likely will have to settle for a chassis dyno instead. I had a spare LS5 that I was going to put together to stock specs. None of the trick stuff mine has... oiling, valvetrain, etc. Just wanted to see the difference.
Prior to 72, GM over rated their engines. There was a story about it in Super Chevy about a decade ago. A 70 LS6 454 450 HP only made about 280 to the wheels. (18-20% drivetrain loss means that it really only made about 340-360 real world HP) They used gross HP rating vs the current SAE net ratings.
A healthy, modded 396 should made 450 HP no problem, maybe more. You'll be more than safe with the 650 HP unit.
I can tell you that when I rebuild my 396/325 I just changed the cam to a RV cam, had the original heads cleaned up and had the original quaderjet gone through and a Corvette aluminum intake and added headers and it made 410 hp and 454 torque @ 3200 rpm for torque on the engine Dyno. Also a stock HEI GM ignition.
The intake was a 427/390 out of 69 so I had to put a riser on for the linkage to work.
Ric Beckman ![]() 1969 Chevelle SS396 1972 Camaro SS350 |
| Thread Tools | |
| Display Modes | |
