Old 06-27-2010, 11:15 PM
Default Just need to Vent
I'm so tired of having delays on this build. Just found out the gauges I have the tach doesn't work correctly. They were supposed to have already been calibrated and working correctly when I purchased them. The owner kept the originals so I had to buy another set. This is not the first time that I have been sold a part that claims to be in mint condition only to find out I got screw again. A lot of money down the drain. I don't buy my stuff off ebay, I look for other sources. Seems like its another delay of a week and move on and it something else so another week there, it's adding up quick trying to get this car done.
Old 06-28-2010, 06:39 AM
That sucks Ray. Makes you feel like it's never going to get finished. Can you work on other areas of the car while waiting for the gauges?
Old 06-28-2010, 11:37 PM
I will be at the show, since I'm working the vendors gates. Won't miss it.
Old 06-28-2010, 11:56 PM
Bowtie-Bri's Avatar
Anytime you work on a car, its always seems to go "One step forward, Two steps back". At least thats how it works for me. Call it Murphys law.
Brian
Old 06-29-2010, 06:07 AM
Hey Brian, how is your car going doing? Did you install a new cam?
Old 06-29-2010, 12:49 PM
Bowtie-Bri's Avatar
Hi Hank,
The engine is pretty much done. I ended up rebuilding the whole top end.Installed new valves,pushrods,springs,roller tip rockers and of course new cam and lifters. I'm also getting a new oilpan because the old one was so rusty, I didn't want to take a chance of developing leaks later on.While I'm at it, I'm going to throw in a new oil pump just to be safe.
I'm also trying to figure out how I'm going to remove the front coil springs without the engine in. I figure it would be alot easier to remove the upper and lower "A" arms so I can replace the 40 year old bushings.
Brian
Old 06-29-2010, 12:57 PM
berner berner is offline
Originally Posted by Bowtie-Bri View Post
.....I'm also trying to figure out how I'm going to remove the front coil springs without the engine in. I figure it would be alot easier to remove the upper and lower "A" arms so I can replace the 40 year old bushings.
You can wrap a chain around the underside of your floor jack and over the top of the frame. The frame won't go up when you raise the floor jack.
Ron
70 factory L48, M20, 3:31 12 bolt project
Old 06-29-2010, 01:24 PM
Removing the springs is easy. You can use Berner's method if there is not enough weight on the front end. Disconnect the lower ball joint, support the lower a-arm with the floor jack. You may have to remove the backing plate because the lower part of the spindle, around the ball joint, sticks into a slot in the backing plate. Swing the spindle out of the way and lower the jack, jack stand under frame. Once the a-arm is all the way down give the spring a swift kick , or just grab hold of it and pull it out, it's not under tension. I wrestled with a spring compressor on one side then realized you can pop the spring in and out by hand once the a-arm is all the way down.
EDIT: Maybe it's the a-arm that sticks through the backing plate. Anyway if you're replacing all 4 bushings you can disconnect either ball joint to start with or both.
Old 07-01-2010, 07:21 PM
I think we should change it from "Murphy's Law" to:
"Classic Car owners Law"
or in my case
"Chevelle's Law"
Old 06-29-2010, 07:37 AM
Been there, done that... no matter how many delays you have, it always becomes "worth it" in the end when you can enjoy it.
