Old 10-09-2010, 07:56 PM
Rattler's Avatar
Rattler Rattler is offline
Default Starting my floor repairs
I finally had some time to start tearing into the cars interior today. I removed all the carpet and pad so I could determine how much of the floor had to be replaced. I'm going to salvage as much of the original floor as possible so I just need to cut out any of the bad flooring areas and weld in replacement pieces.
Here's some pics of my progress so far.
carpet removed.
Floor rusted out around floor support
Rusted areas and patches needed
I'll update with more pics as I go.
Old 10-09-2010, 07:59 PM
Looks like a little bit of work. But at least it looks like you don't have to replace the whole floor. Keep us informed on your progress.
Old 10-09-2010, 08:55 PM
Looks like a bit of work, but repairable. I would check out the rest of the floor for thin spots. It migh be easier to put in a larger repair panel in then have to do it again down the road it the rest of the floor is questionable. Keep us posted on your progress.
Old 10-10-2010, 06:21 AM
bolly's Avatar
bolly bolly is offline
my floor has approx the same areas for work, plus some at the passenger front area... 75% of the rest of the floor I repainted years ago and is still shiney
been thinking 1/4 floors, then 1/2's now a full floor.... and I'm only an amateur welder! LOL!!
will be watching to see what you do
Old 10-10-2010, 08:34 AM
Mike 1972SS's Avatar
Until you sandblast the entire floor, you really don't know the hidden weak spots hiding under the rust. The floor in my Camaro didn't even look that bad until I sandblasted them. Now, I contemplating replacing the whole thing. It all depends on your goals, budget, etc. on what you decide to do with them.
Mike
1972 Chevelle SS
Old 10-15-2010, 11:24 PM
1972convss454 1972convss454 is offline
Mike
X2 I thought the floors in my 72 were good until I got it back from the blaster. Kinda hurt my feelings. I went ahead and purchased a complete floor pan from RPC. They are a great company. I live in TN. Ordered it on Tuesday and it was at my house on Friday.
Progress looks great. Keep us posted.
Joseph Farrow
1972 Chevelle "W" Code Convertible
1970 Chevelle L78
Old 10-10-2010, 10:02 AM
Rattler's Avatar
I've gone over the entire floor with a scraper and hammer. The rest of the floor is very solid. I was actually surprised to see that I had these holes. This is an Arizona car and we really don't run into too much of this out here.
I'm going to cut out the bad spot and see how large the patches will be. If they are larger then expected I can simply cut more out from my replacement floor. Have any of you used any of the dynacorn products? They seem to be the cheepest I've found and there's a shop local to me that has them. Check out this website. They've got some incredible deals! http://www.restorationperformance.co...or-Pan,/Detail
Old 10-11-2010, 02:49 PM
Rattler's Avatar
Any of you ever try corroseal rust converter? I'm going to use it on the areas that are salvageable.
Old 10-11-2010, 04:44 PM
My father used to use rust-mort. It worked pretty good.
Seems like you have your work "cut out" for you man. Sorry.
Old 10-11-2010, 10:11 PM
Rattler's Avatar
lol! yes I do! I didn't have much time after work tonight, but I did manage to cut the bad areas out of the drivers rear. I may cut more just to make the shape easier to work with, but I do have all the rusty floor removed from this section.
