Old 02-14-2012, 09:24 AM
Default i so badly want to hear my chevelle running!
but i am scared to death of hearing this 454 start because i might fall in love with it..lol well the reason why i am posting is because i am to the point where all i need to do is wire it, put oil in it get some gas to the fuel pump and then to the carb, lower rad hose and coolant. so i think! I know i am missing some stuff but i just dont know what i am missing. i am going to post up some pictures now and some when i get home so i can have people chime in on what i am missing and what i need to get
so what does it look like i am missing here?
doesnt the carb get a spring? and a bracket that holds the throttle cable right? does the spring mount on that for the carb to return to closed status? i am looking for new valve covers and hard ware and i want some kind of wire loom to hold it in a neater manner any ideas?
Old 02-14-2012, 10:22 AM
fleming23's Avatar
Based on the look of your motor I would probably get some cheater valve covers in the original style and use the built in wire looms which attach directly to the valve cover.
Originally there was a bracket that mounted to the intake for the carb return spring as seen below by the orange triangular shaped piece with a hole in the middle
Today you can find quite a few variations with the return spring built in. My favorite and the one I use on my motor is the Holley bracket (summit & jegs make their own which are less expensive).
Eric
496 cu. in. "cruiser"
Old 02-14-2012, 11:03 AM
great info! thanks a lot i am going to look up that spring return now!
Old 02-14-2012, 11:22 AM
Is it me or is that Carb at a angle?
Old 02-14-2012, 12:10 PM
it is thats the design of the intake. i am thinking about replacing it
Old 02-14-2012, 12:16 PM
see
Old 02-14-2012, 12:26 PM
fleming23's Avatar
I thought the same thing Ric. I think with the carb at that angle you are going to create more problems than anything else (Throttle & trans cable binding, throttle return spring mounting location, possible fuel line to alternator clearance issues)
Eric
Old 02-14-2012, 05:11 PM
I agree, there are enough issues without all that added stuff. I'd be changing it as well.
Old 02-14-2012, 05:41 PM
Old 02-14-2012, 04:20 PM
Why did they do that ?
