Old 10-31-2014, 11:09 PM
Default what in the. ...again??
Ok I am officially lost! Driving the car tonight for trunk or treat and it did it again. Started hurking and jerking on me and then shut off on me. The gas tank is full and again fuel pump is showing me zero at the gauge. What am I doing wrong here? 2 fuel pumps on less then 150 miles. I am lost!!
Old 11-01-2014, 03:18 AM
Check the carb. Hit the gas are the accelerator pumps squirting? If the gauge is showing empty on a full tank it sounds like a electrical issue issue. Like a main power feed is intermittently cutting out.
Old 11-01-2014, 07:43 PM
its a mechanical pump
Old 11-01-2014, 08:23 PM
What I meant was see if it has gas in the carb. If it does start looking at spark issues. It is just odd you would keep killing fuel pumps they last forever.
Old 11-01-2014, 11:42 PM
my buddy let me use his pump and it started and had 6 psi what does this mean?
Old 11-02-2014, 12:00 AM
I would be checking the fuel pump rod that is in the engine. See if it is freely moving in and out. If it sticks in the bore it isn't pumping.
Pulling the tank and checking the rubber hoses for cracks, suckin air. Looking in the tank for contaminates. Gum parafin is what old 60's gas had that clogged the tanks. Check the fuel lines for rust. Also for possibly suckin air.
I would sure take anything before the pump apart and be inspecting it all. Take the fuel filter apart and see if there is rust or shavings in it. Anything that would destroy the diaphragm or make the check valve stick open.
Old 11-02-2014, 12:11 AM
Most likely the pump you got failed. Get one from GM when you replace it.
Old 11-02-2014, 06:36 PM
gas tank is new all the lines are brand new and all of the rubber hoses have ss braided lines also all brand new. I am thinking its bad pump but how come its going from 8.5 psi down to 0 psi. i am starting to think my push rod is to long and might be over pressing the pump. what do you guys think?
Old 11-03-2014, 08:46 AM
Stock pump pushrod is 5 3/4" long and 1/2" diameter...BBC & SBC are the same.
Old 11-02-2014, 07:04 PM
Shaun, it sounds like you might be right about the push rod. It is not the stock rod is it?
