Old 07-11-2010, 09:12 PM
stalkingbear stalkingbear is offline
Default Posi rearend
xxxxxxxxxxx
Mike
Old 07-12-2010, 08:09 PM
Rattler's Avatar
Rattler Rattler is offline
I've never heard of anyone having this problem in reverse only. I would start with the brakes first since it's the easiest to check out. Does your posi unit require the special friction lube? I've heard units make noises without the right lube in them, but it was never just in reverse.
Old 07-16-2010, 01:55 PM
dbradley dbradley is offline
Make sure you have clearance for the GV/Floorpan. In reverse you may be "raising" the rear of the trans/od assembly and hitting the floor. I'd check the rear mount too.
