Old 01-06-2010, 11:28 AM
rak1's Avatar
rak1 rak1 is offline
Default I didn't know....
So if I get a paint by numbers Camino paint set do I have to use the paints in the kit, or can I change the colors to House of Colors and still be correct? I'm sorry my wife made me do it.....
Old 01-06-2010, 11:30 AM
House of kolors wont be numbers correct
Old 01-06-2010, 11:41 AM
1969 El Camino Dan's Avatar
1969 El Camino Dan 1969 El Camino Dan is offline
Paint codes on the Trim or Cowl tag are specific mix to match Factory GM color chips.
Other colors may not be "Correct" but they might be "Right" if by that you mean - That's what I like!!
Dan
1969 el Camino Custom - SS 350 Phantom
1969 Canadian Malibu - 454 Phantom
1965 Riviera, 1966 Corsa, 1966 Suburban, etc...
Old 01-06-2010, 12:52 PM
rak1's Avatar
I knew Grumpy would understand....
Old 01-06-2010, 12:57 PM
Yup...matching numbers is matching numbers is matching numbers. You're creating a paper trail of illegitimacy when you keep the invoices from paint that does not follow the book.
Old 01-06-2010, 01:32 PM
rak1's Avatar
true, but I was thinking if for some reason you go with the factory correct color and something happens such as you get a paint chip, or scratch getting a matching touch-up could be a problem with an old paint code. Even getting the same shade can be difficult so your saying if your car was being judged it would cost you points. Shouldn't you be marked down just for a repaint then?
Old 01-06-2010, 08:58 PM
Depends on what you're being judged on. For a factory correct restoration you're not marked down for a repaint if the color is correct. Now a repaint will make a car not qualify as a survivor. I think only a small percentage, like 10%, can be repainted and still be considered a survivor. Factory correct and survivor are two totally separate things.
