Ok so i spent the day yesterday putting some of my interior together just because i am getting tired of looking at it the way it is. I got my door panels on and cranks and all that. then i went to put my dash on and plug in as many plugs as i could. I have 5 connectors left. two i will not put up because i know what they are. One is the Radio one is the Lighter. but the three that i have left i am not sure where they go. Now if my wiring diagram is correct and my labels are correct then here is what i have.
these two plugs the ones i have in my hand ![]() they are labeled Ignition. I have nothing on my steering column that has a plug on it. I have one really long plug that if my wiring is correct they are for the turn signals. My question is this the part i am missing from my column? also what size screw/bolts do i need since they are not there. ![]() is it a wiring harness that needs to run to this or is that all i need? How does the car know when the key is being turned? is it from the other big long plug that i plugged in? the other connection that i am missing is (if my wiring is correct) i have it labeled as reverse signal. which i think is this one here ![]() no clue where that goes and am i missing a harness that goes from the trans to this? thanks for your help!
2005 dodge magnum daily driver 1988 mazda rx7 LS6 swap 1969 SS work in progress Last edited by SS Shaun; 05-10-2012 at 09:46 AM. |
I need to check, but I believe the two you are holding go into the white connector you have pictured. The connector is on the bottom side in this picture.
yeah ground up just emailed me back about it thats the part i am missing. I ordered it so it should be here tuesday i hope. now i just need to figure out what size bolts i need there. i forgot to ask him in the email. now about that reverse signal wiring is what i need to figure out.
| Thread Tools | |
| Display Modes | |
