Old 08-04-2012, 01:20 PM
Get a 454, don't look back. (same outward appearance as a 396) You'll engine the extra TQ it has. Never heard of those mufflers. Get everything swapped over and see how it sounds. If it doesn't fit the bill, try a set of Magnaflows.
Old 08-05-2012, 01:36 AM
where do you live i have a 454 with a big block you can buy off me
Old 08-05-2012, 04:05 AM
TD72chevelle TD72chevelle is offline
I live in Canada. What would you want for it? Is it just the block or is it complete?
Old 08-05-2012, 12:46 PM
that would be one hell of a shipping cost..lol it would be complete all you would need is to wire it up and go
Old 08-06-2012, 05:35 AM
Yea it would be. I got a guy I know in Albany though that might be able to get it for me if need be. Do you have a price so I can figure out if its in my budget for this year?
Old 08-06-2012, 09:52 AM
no clue any more on what to sell it for. i was thinking 2500 but no clue anymore what i want to sell it for
Old 08-06-2012, 10:17 AM
Well if you're not sure if you want to sell it for that no worries. If you want to talk more about it you can private message me. Thanks tor letting me know do quickly though.
Old 08-12-2012, 10:14 PM
Bama Bama is offline
I've got the same problem, but my 72 came with a 1984 305 from a truck, not sure what I'm gonna go with either, let me know what you decide.
Old 08-28-2012, 12:52 PM
Berg's Avatar
Berg Berg is offline
I don't have any experience with the sonic turbo's but I can tell you that the old 400ci smallblock in my old black Malibu was a great little engine with plenty of power. You could swap in a healthy SBC chevy and keep all the accessories and mounts and not have to worry about modifying driveshafts or anything too. It is the cheapest way to go. An old performance rule was 1hp per cubic inch was a good baseline. I am a Big Block guy (hence the 454 in my current Chevelle and my Suburban I use for towing) but I wouldn't rule out a healthy streetable mouse motor. Doing a big block swap correctly costs a lot more than some people realize. For starters, you are going to want to upgrade your front springs and sway bar at the least, most likely add a rear sway bar and boxed control arms- and throw enough HP and torque at the 10 bolt rear and see what kind of carnage you get. IMO anything around 400hp and over and I'd be running a 12 bolt or a Dana 60 or 9" F**d rear. That alone is going to require fabrication to put a non GM axle in if you can't score a good deal on a 12B. Don't forget you'll need a new radiator and fan shroud and accessory brackets for your power steering and alternator. You now have my .02 )
84 K5 Blazer 350/SM465
75 K5 Blazer 355/SM465/8 lugs
Old 09-05-2012, 08:20 PM
Speaking of the rear end, i have a couple pictures of it and as far as i can tell it is a 12bolt and i do believe the control arms are boxed as well. Let me know if i am mistaken or not.
