Old 03-02-2013, 04:48 AM
xtopfuel xtopfuel is offline
that is what i thought, i have a list of numbers but had a hard time with the
T032OLD # once i get it on a stand i will find the casting, so new direction may be a copo tribute any opinions on that
Old 03-02-2013, 07:37 AM
How about an L78 68 Chevelle. Not sure if the Copo was done on a 68 Chevelle. I believe it was done in 69.
Old 03-02-2013, 09:34 AM
DVSentinel DVSentinel is offline
Location: Currently change between two locations, OKC and Harelton Texas
Block casting will give you the series of engine. The T0320LD gives you the date of manufacture, where it was built and the LD suffix tells you what car/options it was built with. So the T0320LD is more specific. But the casting will tell you things like 4/2 bolt, and help determine things like journal size, if non standard.
Since it came with a standard transmission, this tells you to check to see if the pilot bearing is still in the crank and to remove it if you want to put an automatic in the car, or if missing, put it back before installing a standard trans.
Old 03-06-2013, 07:26 PM
great, thanks fgor the info, picked up the engine today, will get off the trailer and on a stand then post some pics
Old 03-08-2013, 07:31 AM
welcome to the site! very nice 68
Old 03-10-2013, 11:47 AM
Mrs.Angel Mrs.Angel is offline
Welcome I am a new member as well!
Old 03-13-2013, 05:09 AM
if i can get a free minute from business i will post some pics of the heads, block and some new toys i just got saturday
Old 03-13-2013, 08:54 PM
Always like the new toys.
