#11
Rear seat should be 58" I believe. The 69 if I remember correctly did not use a filler panel like 70, the arm rest with the ash tray was mounted to the rear side panel.
Ray 1970 SS Chevelle Van Nuys Built Last edited by shadowgray396; 01-01-2014 at 11:04 AM. |
#12
Buick and olds used a filler panel and Chevelle did not. Some info I found All 68/69 rear seats are not the same for hardtops. Only the ones with Olds or Buick seat covers were the same. If used in a Chevelle and came with either an Olds or a Buick seat cover, that seat is the narrower seat that was really an Olds or Buick application. I understand this may get confusing. 68/69 two door Chevelle had 3 different seats, The Wider Chevelle seat, the narrower Olds/ Buick seat and the convertible seat. To make things a little more complicated
Ray 1970 SS Chevelle Van Nuys Built Last edited by shadowgray396; 01-01-2014 at 11:08 AM. |
#13
they came out of a 68 chevelle with a 307 in it (not sure if that matters) i was looking around a bit and found that some guys with 69s do have that plastic filler in it. I am going to go check out a friend of mine's 69 tomorrow to see what he has in his
#14
307 should not matter, this is a 69 SS back seat.
#15
Ray had posted this information from an earlier post "rear seat question". Maybe these measurements will help.
This is from your other post earlier 68-69 rear seats are 58", 70-72 coupes are 54.5", 70 to 72 use a filler panel in the back that the ash tray sits in. 68-72 convertibles are 52". __________________
#16
I guess I got vert seats then they come in just over 52 inches I am starting to hate this car again and some of the dishonest people and I was willing to buy new frames but can't find any I give up
#17
If they are vert seats you should not have a hard time selling them ,good luck .
John |
#18
I can't tell you how many times I was told the part was for a 70 and it was not. I feel your pain.
#19
Need to make a correction to that. I was told wrong by a friend Coupes for 70-72 are 52" Convertibles are 48" I checked my 70 and it is 52"
#20
69 back seat picture
Ray 1970 SS Chevelle Van Nuys Built Last edited by shadowgray396; 01-01-2014 at 09:23 PM. |
| Thread Tools | |
| Display Modes | |
