Old 02-01-2015, 11:28 AM
Nancy called you a smart ASH, lol
Old 02-06-2015, 08:40 AM
I drove the truck to work yesterday ,its been to dang cold most mornings lately to drive it ,no heat with the Vintage Air ,Im going to try another thermostat and see if it helps .
On mine, it has an electronic water valve and must be installed a particular way for it to work. Have you checked this? As I recall, you have to program the system by jumpering a white wire to a ground which then caused all the actuators and motors to self-learn. Just a thought because the Chevelle only runs 155-160 degrees down the road in this cold weather but still blows nice and warm through the vent. I can't imagine the thermostat would have you running so cold that you get no heat, but I suppose it is a cheap part to swap out and see.
Old 02-06-2015, 09:26 AM
I changed the thermostat and still very little heat ,both heater hoses are plenty hot so water is getting past the valve .I need to look online for a set of instructions as they were left at the shop when they installed it .And unfortunately Neil left the bodyshop and he installed it .
Old 02-06-2015, 01:19 PM
Here 'ya go John...
http://www.vintageair.com/downloads.asp
Old 02-06-2015, 07:09 PM
Thanks Bill ,that will help a lot .
Old 02-10-2015, 08:03 AM
I love these old cars/trucks but they are always a work in progress. Even when you think that you are done there is always something else to do. lol
I hope you have been able to find the problem flash.
Old 02-10-2015, 08:37 AM
I have not felt up to doing anything yet .
Old 02-11-2015, 05:44 PM
I hope you feel better soon flash..
Old 02-11-2015, 06:34 PM
Thanks ,I have been fighting this crud off and on since Thanksgiving ,felt the best today than in a long time .
Old 02-12-2015, 04:48 AM
Hope you are getting better John.
