Old 05-15-2015, 10:11 PM
Originally Posted by John View Post
Carpool- that's a stock radiator with that top mount neck? I placed the radiator temporarily in place last night and it surprisingly clears. But only by a hair. DeWitt's says they can swap out the radiator if I wish which is pretty decent of them. Not sure what I want to do now.
It's a DeWitt's, aluminum with the black coating. Stock-type appearance.1239003M is their part #.
Old 05-16-2015, 08:48 AM
John's Avatar
John John is offline
Carpool I can't clearly see is your filler neck mounted straight up on top?
Old 05-18-2015, 08:28 AM
John's Avatar
Got the Dewitt's installed this weekend. I kept the one they sent- filler neck on top. It cleared the hood although very close. It's a big core, two rows of 1-1/4" tubes. So far I am happy with results but I don't know for sure if I'll get the electric fan assembly or stay with stock fan. It still wanted to creep when idling. I sat for a bit maybe 5-6 minutes and it got to 180. Temps that day were in the mid 80's. The big difference I noticed is it runs right at 160 when driving. I have a 160 degree thermo but rarely did it sit at 160 while driving unless very cool outside. I have no doubt if I did get the electric fans, I'll have no more temp issue's. After sitting and letting the temp get to 180, within a minute of moving again, temps came right down telling me with the right CFM of air being moved through the radiator it can easily handle the heat.
Old 05-18-2015, 05:15 PM
John, it's after the fact... but I did find a couple of better pictures.
ID:	3558   Click image for larger version
