Old 09-22-2017, 09:37 AM
Originally Posted by colpac View Post
It does have a opening to the rear of hood but I can not see where the air would get in the breather unless it does not touch the hood.
Okay, the rubber seal around the air cleaner fits up against the hood. You're saying that section of the hood does not open to the rear?
Old 09-22-2017, 10:58 AM
colpac colpac is offline
Thanks, that would be great !!
Old 09-22-2017, 11:02 AM
Yes, from what I can tell there is no opening to the rear except a small area about half inch by two inches long. You can see it in the one photo at the top of the off set
Old 09-23-2017, 09:14 AM
Ok, first my flapper hood...
ID:	4202   Click image for larger version
ID:	4203   Click image for larger version
ID:	4204   Click image for larger version
Old 09-23-2017, 09:17 AM
Now the domed hood...
See the obvious difference between the inner structure? Hence why I recommend an air pan to make a domed hood functional.
ID:	4206   Click image for larger version
Old 09-24-2017, 07:56 AM
OK, I see what you are saying, mind is the domed hood. Thanks for the info. Would like to make my inlet to get some air in. Thinking all I have now is just through the air breather inlet.
Old 09-25-2017, 12:10 PM
You are most likely picking up air from the engine compartment. Go with an air pan set up. Simple to fabricate, or they sell trim to fit kits.
Old 09-25-2017, 01:44 PM
Thanks, will check it out !
