need help on diagnosing caliper piston retraction
my front disc pads are dragging too much, both sides. It's a 69 Chevelle with the stock setup. I installed new calipers but that didn't solve the problem. I greased the pins and the calipers slide good. When I bleed them, the fluid pumped through easy, and the pedal feels ok.
could the master cylinder piston cause the caliper piston to not retract? Last edited by Neutral; 07-20-2023 at 11:05 AM. |
Thread Tools | |
Display Modes | |
