Old 01-05-2010, 10:37 PM
68 nova 10.5's Avatar
68 nova 10.5 68 nova 10.5 is offline
Send a message via Yahoo to 68 nova 10.5
Nice build looks like your compression will end up around 8.7-1 I would zero deck this engine and maybe mill the heads and use a thin gasket to get the compression up as much as possible(although not necessary) the rpm is the perfect intake for this Build up.
Old 01-05-2010, 11:12 PM
1969 El Camino Dan's Avatar
1969 El Camino Dan 1969 El Camino Dan is offline
Tom M. in a PM, brought my attention to the "issue" of the cast iron roller crank mentioned in my list above.
Has anyone used any techniques or coatings to improve cam life, such as Lubriplate?
Or any other suggestions to help keep my first BBC together.
I know I need to get a cam button for the build.
Thanks
Dan
1969 el Camino Custom - SS 350 Phantom
1969 Canadian Malibu - 454 Phantom
1965 Riviera, 1966 Corsa, 1966 Suburban, etc...
Old 01-05-2010, 11:29 PM
piette's Avatar
piette piette is offline
I've never used any of the coatings. I did run a Comp 288AR solid roller and it was a -8 cam as well. I never had a problem with mine, but there is no guarantee ever with the cast roller cams.
Looks like its going to be a fun engine you are putting together, hope it all works out for you
Jeff
Jeff
Old 01-06-2010, 10:30 AM
Just picked up a set of stainless bolts for the engine. - Intake, down to oil pan. Nice looking kit for $50.
Where is the best place to get my Head & bottom end bolts? I've got a windage tray to install.
Also, what head gasket part number do I need to get.?
I've got an aluminum 3 core radiator on the way. $170 delivered to the door. I post up some pics when it arrives.
Dan
Old 01-06-2010, 07:54 PM
piette's Avatar
Well myself, I always and only use ARP head bolts and all ARP studs in the bottom end. Adding ARP bolts or studs really beefs up an otherwise stock bottom end.
As for the head gasket, I always use a Fel-Pro 1017-1, but I would try to go a bit thinner and boost the compression in this case. I would have to do a search of the head gaskets to figure out which one would be thinner.
jeff
Jeff
Old 01-06-2010, 08:11 PM
Arrow Here's the Aluminum radiator - It came today
Arrived on the doorstep today.
All Aluminum, built in cooler. Looks like it's put together nicely. They have great feedback on this A body radiator, so I was pretty confident in ordering it.
I'll have to fill 'er up and pressure test it
This is the only thing that ticks me off, so far. Why cant a company here in the U.S.A. or Canada make a product like this for the same reasonable price??
Regulations? Lawyers? Taxes? Labor? - I guess it all figures in. Sigh....
For $170 delivered to my door, I'm quite happy.
Dan
Old 01-06-2010, 08:20 PM
grumpy's Avatar
grumpy grumpy is offline
Administrator Bowtie Member
Dan
Its labor that is a huge part of the US made parts.
Dave
Old 01-10-2010, 09:57 PM
russ67chevelle russ67chevelle is offline
id do a rpm intake with any where from 800-950...please put a 400 behind it...good luck hookin er
Old 01-11-2010, 12:04 AM
Aw..'cmon Russ -- a Muscle car needs a 4 speed!!
At least I do! This ain't a drag car, but I'm looking forward to jammin' the gears.
This is gonna be some fun!!
I love the sound of a tough big block. Went to one of the get togethers at Doc 'n Tammy's place and even though I'm half deaf, I was hooked!!
What a great sound!!
Dan
Old 01-14-2010, 12:31 PM
Default Stainless Bolt kit
Picked up this very impressive bolt kit from eBay seller AlloyBoltz
Under $50 delivered to my door.
Dan
Tags
454, engine build, hydraulic roller cam, pistons
