Old 01-12-2012, 11:25 AM
93svtlightning 93svtlightning is offline
I have a 2010 camaro 2SS mostly stock just 3in jba catback and pfadt swaybars and lowering springs.
1991 jeep wrangler stock for now going to lift it 4in and put 33s on it
Then we have my pride and joy 1993 ford lightning with a 408 stroker
1969 chevelle ss convertible (project), 1965 Chevrolet C10, 1993 ford lightning, 1991 Mustang Coupe Coyote Swap, 2014 f250 6.7 Powerstroke
Old 01-12-2012, 02:21 PM
Sounds like you have a vehicle for many different situations.
Old 01-12-2012, 03:57 PM
68ChevelleSS's Avatar
Welcome to the site! Can't wait to see some pics of your vehicles
Boyd
Old 01-12-2012, 08:09 PM
I always wanted one of those lightnin trucks and Im a Chevy guy mostly ,but I do own a 96 Explorer and a 2004 Sport Trac as daily drivers.
Old 01-12-2012, 11:47 PM
Welcome Steven to the site. Let me ask a couple of questions. Do you have documentation for the car and what size engine do you have for it? From 68 down the SS package was a model number that started with a 138 vin number. Reason I ask is that for me that would determine how I would restore it. Here's some info on 69 attached. I'm working on a 6 year restoration.
From 1969 on, the SS was no longer a separate model. Instead, it was now an "SS" option package added to a 300 Deluxe model, Malibu model, or El Camino Custom model. 1969 was the only model year that the SS package could be ordered on the base model Chevelle 300 Deluxe (as a 2-door coupe or a 2-door post sedan). The only SS option in '69 was the "Z25" SS-396 package. The '69 and up cars are harder to authenticate because the VIN can not be used to confirm if the car is an SS.
There were two colors that were exclusive to the '69 SS. "Monaco Orange" (code 72) and "Daytona Yellow" (code 76). If either of these paint codes appear on the cowl tag (and the cowl tag is genuine) then that would prove the car to be a genuine SS.
If someone had a nice '69 Malibu, and a rusted out '69 SS, it would be easy for them to simply move the SS equipment over to the Malibu. As long as they did not alter or move the VIN plates or cowl tags, this would be perfectly legal, and since the VIN tag doesn't tell you much, there would be almost no way for you to know.
From '69 on, single-piston disk brakes were STANDARD equipment with the SS package. These brakes are easier to find parts for than the earlier four-piston disk brakes.
Chevrolet literature indicates that the only way to get a 396 was with the SS package. However, there appears to be at least one late-production Chevelle that was built with a 396 and all the required SS equipment, but the "Z25" SS-396 option was not listed on the car's build sheet. It is believed that this car came from the factory with "SS" emblems, but that is not 100% certain.
Again in 1969, the only available SS engine was the 396 (in the same flavors as in 1968). In 1969, however, it was possible (if you knew who to talk to) to order something called a COPO 427 Chevelle. COPO stands for "Central Office Production Order". The COPO program allowed dealers to order equipment that was not usually available (such as special paint, special engines, etc.) Unlike the '68s, the '69 Chevelles had their 427 engines installed at the FACTORY, not the dealership. This makes the '69 427s more legitimate in the eyes of collectors today. You didn't necessarily have to go to Yenko or some other special dealer in '69 to get a 427 Chevelle. Your local dealer could usually get you one if you filled out the right paperwork. While the '69 COPO 427s had basically the same equipment as the SS-396s, they were not generally considered SSs because they did not have any external "SS" or "427" identification. They were the ultimate sleepers. Any genuine '69 COPO 427 Chevelle is quite valuable today. There are also unconfirmed reports of a '69 COPO 427 El Camino.
In addition, there was an "L89" aluminum head option available for the '69 375 HP 396. Few were ordered.
1969 SSs had "SS/396" emblems on the front, back, fenders, door panels, on the dash above the glove box, and on the standard SS steering wheel. The '69 SS also had the twin-bulge hood like the '68s, but the bolt holes where the hood hinges attached were slightly different. The '69 SS came with 14" SS wheels with "SS" center caps. The '69 SS stripe option consisted of a black, white, or red stripe which ran along the upper body sides. There are also reports of a few '69 SSs with dealer-painted hood stripes, similar to the stripes used on many '70-'72 SSs.
Another rare car, produced only in '69, was an SS Chevelle built on the 2-door post sedan, the "Chevelle 300". This was the only year that a 2-door post sedan SS was produced. Most of the '69 SSs, and all the '70-'72 SSs, were built upon the 2-door Malibu pillarless coupe.
Old 01-13-2012, 08:18 AM
No documentation to my knowlegde. But my stepdad is 2nd owner he got it in 73 or 75 can't remember and says he has the original motor still I plan on checking the numbers. The original motor was a 396. It was a 396 4 speed car
Old 01-13-2012, 10:41 PM
Here's where to look for the numbers on the engine.
I'm thinking build it the way you want, if you have no documentation, but check the motor and trans numbers and see if they match the vin.
