Old 10-08-2012, 10:57 AM
Rattler's Avatar
Rattler Rattler is offline
UPDATE: The 383 is gone. I sold the longblock for 2K. Kind of cheap, but I needed it gone.
I also got the trans tunnel opened up and mounted the transmission for mock up.
Tunnel was opened up 4" total to make room for this T56
I've still got some more work to do, but it's getting there.
Crossmember worked perfectly without modification.
Old 10-08-2012, 11:15 PM
Nice work, your set up is looking good.
Old 10-08-2012, 11:29 PM
wow nice work man! i like it! get it done so i can see it and get mine done like that only thing is mine will be a 408 lq9
Old 10-21-2012, 10:41 PM
Rattler's Avatar
I finished up the tunnel last weekend. Made the very rear removable with rivnuts. This will allow me to pull the cover so the trans can be removed separately from the motor if I need to work on it.
Tunnel complete
This weekend I started off by getting my hydraulic clutch setup working. I bought a bracket off of ebay that mounts the clutch master cylinder and then installed my 1964 clutch pedal. I welded a tab onto the clutch pedal to connect the hydraulic clutch rod to my pedal.
Old 10-21-2012, 10:49 PM
Rattler's Avatar
Got some goodies in the mail and started my fuel system.
Walbro 255 fuel pump mounted behind fuel cell
Corvette filter/regulator mounted up. Fuel system is now complete
Drilled and tapped my water pump for the steam vent.
Drilled and tapped for oil pressure gauge.
Rattler's Avatar
And started working on my harness. Hope to start it next weekend!
Old 10-22-2012, 08:40 AM
wow good job man i am very jealous!
Old 10-22-2012, 05:00 PM
Same here.
And I love the idea of being able to pull the motor or trans separately. Great Job.
Old 10-22-2012, 08:08 PM
Looks good ,keep up the fun work .
Old 10-23-2012, 08:19 AM
Looking good, keep sending pictures
