Old 09-30-2013, 10:28 PM
hkalin's Avatar
hkalin hkalin is offline
I can look at the factory assembly again but I think they both go in with threads forward. That's how mine is and I'm sure I looked at the assembly manual when I put it together.
My manual says left hand side threads toward back right hand side the opposite.
Old 10-01-2013, 06:58 AM
Okay then, guess I,m not remembering correctly, been a few years.
Old 10-02-2013, 04:50 PM
John's Avatar
John John is offline
I've only seen it threads facing forward both bolts.
Old 10-02-2013, 06:50 PM
hkalin's Avatar
I personally don't see why both bolts can't have the threads facing forward. I'm only saying the assembly manual says the left one's threads face back and the other side is opposite.
Old 10-06-2013, 07:31 PM
70SS454's Avatar
70SS454 70SS454 is offline
I just pulled my engine. The right bolt was in back to front. The left was front to back. I believe that was because you can't get the left in from back to front due to a lack of space.
Old 10-07-2013, 06:55 AM
John's Avatar
I think I may have come up with a way to remove the bolt on the fuel pump side without taking out the pump. If I can cut off the head of the bolt and push it back out towards the rear, I can then insert the new bolt from the rear and essentially never mess with the pump. I think I have enough room to get a sawzaw in there with a sharp metal cutting blade and cut that off. Any thoughts?
Old 10-07-2013, 07:44 AM
hkalin's Avatar
If its a Grade 8 bolt will a Sawzaw cut thru it. If not could you get in there with a cut off wheel. As you jack the motor there is a point where the bolt should become loose enough to remove by hand but if you jack the motor too much it will become tight again. I use a bottle jack and piece of 2x4 also. You want this piece of wood to be long enough so it goes past each side of the pan by at least an inch.
Old 10-07-2013, 02:59 PM
I think it would be easier to remove the lines and 2 bolts from the fuel pump, just my opinion. As mentioned cutting through a hardened bolt won't be easy.
Old 10-07-2013, 06:28 PM
hkalin's Avatar
I have to agree with you the only thing John has to remember is when he reinstalls the fuel pump he has to make sure the rod that works the fuel pump is pushed up or he'll never get the pump back in.
Old 10-11-2013, 08:48 AM
John's Avatar
That's why I'd rather try cutting the bolt than removing the pump. Didn't want to mess with the push rod. Of course, I'd be prepared to go that route if indeed the bolt didn't cut well or I don't have the space to really work in. Just thought I'd bring it up. thanks for the feed back.
