Old 11-03-2014, 07:48 AM
Ken its an Comp Cam push rod i got from summit i have the part number let me look it up and i will post it. I dont want to cut the pump because it still covered under warranty i think
Old 11-03-2014, 08:46 AM
Originally Posted by SS Shaun View Post
i am starting to think my push rod is to long and might be over pressing the pump. what do you guys think?
Stock pump pushrod is 5 3/4" long and 1/2" diameter...BBC & SBC are the same.
Old 11-03-2014, 02:11 PM
here is the push rod i am using in my motor now
http://www.summitracing.com/parts/cca-4607
Old 11-03-2014, 02:40 PM
Ken Hayes's Avatar
Well, that's the correct size Shaun. I guess its time to go electric.
Old 11-03-2014, 03:09 PM
I'd pull the fuel pump and take a good loon look at it's pump lever.
Any indications of the pushrod skipping off the pump lever...either on the end or off to the side.
Like I mentioned previously...earlier this summer, I got FOUR bad pumps in a row from O'Reilly. The levers were too short allowing the pushrod to fall off the lever's end.
Old 11-04-2014, 08:19 AM
well i think i am going to have to put the blame on the push rod. I can't get it out for some reason! I pulled the fuel pump out, opened the screwed in bolt on the bottom of the block and turned the key once just to see if it would move and it moved but only seemed to be about a half inch to 3/4 of an inch. I can push the rod up and spin it freely. I got a needle nose and tried to pull on it and nothing. i put as much force on it as i could, but nothing! now what? i can't leave that push rod in place and go electric can i? I have to remove that rod correct?
Old 11-04-2014, 09:41 AM
At the front of the block there is a 3/8 bolt hole that intersects
the pushrod hole....Make sure the bolt that is supposed to seal this hole
is not to long and rubing on the pump rod.
Old 11-04-2014, 10:27 AM
not sure what you mean its a big block i thought only the small block had that
Old 11-04-2014, 10:29 AM
this is what you are talking about
Old 11-04-2014, 11:33 AM
That is it.
