Old 06-07-2010, 05:11 PM
zombie1969's Avatar
Another thing that may help is getting your alignment checked.If your caster or camber are too far out of wac itl throw everything off.
Old 06-07-2010, 05:52 PM
crankshaft crankshaft is offline
Hmmmm ,,, centerlink seems to be sitting lower than mine ,,, but then again...
thanks for posting the pics and the quick reply zombie.
Old 06-07-2010, 05:56 PM
http://imagebin.ca/view/lCKyxlc.html
when the engine was pulled out, found theframe mounts loose,, but that wouldn't cause it to sit so low...
Old 06-07-2010, 05:58 PM
i ordered a set of motor mounts from energy suspension,,, identical to what I removed from the car,, replaced the oil pan with a stock replacement,,, identical to the beaten up oil pan that was on the car.... a source mentioned to me that maybe I havethe frame mounts for a 6 cylinder instead on a v8 ? Make any sense ???
Old 06-07-2010, 06:06 PM
zombie1969's Avatar
Check your vin.Is it an original v8 car?
Old 06-07-2010, 07:35 PM
vin # 138375z130047
Old 06-07-2010, 08:33 PM
zombie1969's Avatar
Its an original v8 car.
Old 06-08-2010, 06:39 PM
I guess that after so many years and owners and mechanics tampering with it, who knows whats been done or modified with the car. Could be a number of things , especially if different year parts were put in ... spindels, front frame, etc ???
Old 06-08-2010, 07:41 PM
zombie1969's Avatar
Sometimes its easiest to take a look at another car and try to figure it out.You said you replaced the mounts that bolt to the frame and they were the same as the ones you already had.Maybe the mounts on the block are wrong.What else is there.If your pictures were a little better quality I could compare yours to what mine is.You keep showing the pan on the frame but not the mounts in question.Unless there there someplace and I missed them.Rank was saying earlier you might have the wrong pan.Hard to tell but yours looks more squared off where its hitting and mine is rounded.May be deeper as well.I got my pan from summit.Nothing special besides the chrome.Stock oil capasity.
Old 06-09-2010, 06:17 PM
hi zombie,,, I compared your pics to mine your centerlink (draglink) seems longer and hangs lower ,,, which has me thinking that maybe I have the wrong front end parts. I didn't replace the frame mounts... I replaced the motor mounts (rubber portion bolted to block). Yes i said that the clearance between my oil pan and crossmember was close, but then again I found the frame mounts completly loose. If you compare the draglink from yours to mine ,,, you see a big difference. What do you think ?
