Old 01-07-2010, 03:04 PM
1966_L78's Avatar
1966_L78 1966_L78 is offline
Originally Posted by rak1 View Post
Andy, It seems to be hit and run on gallery attachments; I added Thumbnails on post #13 so you should be able to see them now. Tony, I'll try a dropbase to see if it helps; I had the SS hood on it before and it was hitting on the air cleaner way before it closed. Anything is better then having to buy another hood and I can pick up a base for under $10. Thanks everyone for the help and support!
I can see the pictures everytime ( which is good, because my work blocks alot of photo-storage sites)...
Personal choice, I preffer the stock SS hood over Cowl hood any day ( but thats just me), especially the '67 SS hood.
Lots of fab work, but I'd consider modifying the SS hood somehow ( building the cowl scoop between the bulges for the extra clearance, etc) before I'd put a generic cowl hood on... But sometimes, it might be the easiest ( and least expensive)...
I'd say the drop-base is at least 1 to 1-1/2 lower, plus that aircleaner on yours looks like it sits pretty high on the carb ( maybe an inch from bottom of filter to the ac mounting surface on carb), I don't remember mine sitting up that much off the carb ( but it does have to clear the accelerator pump on the Edel carb, so it can't be flush)...
Tony
1970 427 SB, PT "Poser"
1966 L78, waiting patiently
And many previous Chevelles
Old 01-07-2010, 03:56 PM
rak1's Avatar
rak1 rak1 is offline
Thanks for all the help Tony and I agree 100% I don't want to buy another Hood if I can avoid it and I like the sleeper look of the SS hood. I'm planning on going by Summit tomorrow and buying a 14 inch drop base and giving it a try this weekend.
Old 01-07-2010, 04:23 PM
1966_L78's Avatar
different angle than your picture, but here you can barely see the Edelbrock carb at all...
, RPM air-gap, 5" tall filter, and I still have more room under the hood... Of course, this is one my '70 with the domed SS hood... I think its the cheap Summit base too...
Boy do I need a newer picture ( that was while it was in the body shop)...
Tony
