Old 01-24-2014, 02:40 AM
caljon88's Avatar
caljon88 caljon88 is offline
Found a set of wheels and tires at a SUPER good price!!! They are 17" Boyd Junk Yard wheels. The tires are not new but in good condition. They are bigger than I wanted but I just can't pass up the bargain.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Old 01-24-2014, 08:31 PM
Should look good on there.
Old 02-01-2014, 07:51 PM
caljon88's Avatar
I threw the wheels on and put the fender on to see how it looks.
ID:	3112Click image for larger version
ID:	3113Click image for larger version
Old 02-01-2014, 07:55 PM
Those wheels look good .
Old 02-15-2014, 02:23 PM
caljon88's Avatar
Taking the rear control arms off today. I have three of four unhooked but the passenger side must be twisted because I can't get the bolt out!!! Round two is tomorrow when I can get some help. Ugh!
Sent from my Nexus 7 using Tapatalk
Old 02-15-2014, 05:36 PM
Did you spray the bolt with PB Blaster or WD 40 to break the rust. I had a hard time getting some of my bolts out. Maybe even heat would help.
Old 02-15-2014, 09:30 PM
caljon88's Avatar
It spins, I just can't get it to push threw. I'll have my dad to help so I can put some pressure on the back side. I did spray WD on and that helped a ton!!!
Old 02-15-2014, 11:54 PM
If I remember correctly on one of mine I had to cut the bolt to get it off.
Old 02-16-2014, 12:42 AM
If you have an air hammer with a punch type tip or even screwdriver and a hammer, you could put it on the end of the bolt and maybe drive it back through.
Old 02-16-2014, 06:58 PM
caljon88's Avatar
Got it! I had to cut 2 and beat the others out. The upper control arms came off easy. I'm going to order and new bolt kit to reinstall. I don't have an air compressor yet but hopefully I'll have one soon. I think air tools would make a few jobs easier.
