Old 11-04-2014, 01:55 PM
thats small block big block doent have that i thought
Old 11-04-2014, 01:59 PM
Has a fuel pump there it has it. Newer electric fuel pump trucks may not. But same applies to the small block 6's and 4's. Once they had a factory electric. They rough cast it but never bored the hole to fit the rod.
Old 11-04-2014, 04:04 PM
Push rod must have a mushroomed end. What style cam is in the engine? HR, flat tappet?
Old 11-04-2014, 09:13 PM
Flat tappet, i got it out finally
so it looks like the bronze tip mushroomed and collapsed so i guess i know now i need a new push rod
Old 11-04-2014, 11:14 PM
Ken Hayes's Avatar
Look for the 7/16" missing from that rod. You should get this one from Summit, Carter PR-1 - Carter Mechanical Fuel Pump Pushrods # CTR-PR-1 $11.97 this one is chrome moly with no bronze tips.
Old 11-05-2014, 06:32 AM
No bronze tip pushrod needed on a flat tappet cam!! I hope it didn't eat up the lobe.
Next question is...where is all that metal that's missing from the pushrod??
Old 11-05-2014, 09:34 AM
i was wondering the same thing about where is all the bronze then i looked at the push rod some more it literally looks like the bronze was smashed in the push rod. If not it must of broke apart while it was running. I drained the oil and ran it in a strainer. I found some small parts of bronze like metal but i was not sure about it. I put new oil in it and i have normal oil pressure. I don't know what else to do as far as all the extra metal.
Old 11-05-2014, 10:35 AM
Ken Hayes's Avatar
Shaun, is that pushrod hollow? If so, seein your not gonna use it again, cut it and see if you can push the bronze piece out of it. 7/16" of metal is a lot to lose. I know those bronze ends are not that long.
Old 11-05-2014, 09:47 PM
Ken you called it bro. I cut it and there it was a nice big thick piece of bronze stuffed in it
not sure if you guys can see this video but my daughter was SO happy to see it back she literally ran to the door jumping up and down!
http://videos-a-13.ak.instagram.com/...14099999_n.mp4
Old 11-05-2014, 11:41 PM
That is so cute. She is a little doll baby. My son gets all excited like that.
