Old 07-22-2013, 07:04 AM
I would try Hinshaws .
I will check with them. If not Im gonna have to machine one.
Started on getting dash and wiring installed. First thing I had to do was replace the 2 speed indicator to the 3 speed indicator. Click image for larger version
Old 07-26-2013, 06:47 PM
No luck finding a 90 degree part to connect my flapper. Going to look for one as I progress along with the project.
Right now Im working on installing the new wire harness. Ive got most the dash connectors located. Im stumped on two connectors.
The markings on the new wires don't seem to jive with the old stuff or Im lost. Very possible Im off! If only the new harness tech support was open nights and weekends.
I cant seem to find were to connect the idiot lights bulb sockets to the new harness? Where's the hi beam indicator located on a 72? Can not remember
Can any body advise about were the wires in the diagram connect to?
ID:	2762Click image for larger version
ID:	2763Click image for larger version
ID:	2764Click image for larger version
ID:	2765Click image for larger version
Old 07-29-2013, 06:07 PM
Now it all makes sense. Found this. Click image for larger version
Old 07-30-2013, 07:02 AM
It seems there is a update harness and a OEM replacement harness. I have the update, but want to use stock sweep gauges. Calling tech support today!
Were is everyone these dayz? Have I bored everyone?
Old 07-30-2013, 09:20 AM
Figured you had it all figured it out. What 90 degree are you missing for the flapper?
Old 07-31-2013, 06:23 AM
Its the part that connects the flapper to the actuator.
Old 08-04-2013, 04:07 AM
Here is a picture of the broken 90 degree bracket needed.
Old 08-04-2013, 12:04 PM
Got the dash harness in. It took me a little extra time, but I soldered and heat shrunk all the connections.
Im stumped on how the top row of speedometer lights are getting there power. I didn't see any wires powering the strip going to the bulbs. Any idea were the blueish looking strip in the photo gets power?
Old 08-04-2013, 05:43 PM
Well dash is back in and wired up. Also laid out the engine harness and front light harnes.Click image for larger version
ID:	2778Click image for larger version
The American auto wire kit is very nice. Im glad Im updating the fuse box and all the wiring!
Old 08-04-2013, 10:39 PM
Attachment 2775
I have not seen that bracket before. My pods bolts directly to my outside cowl induction door, without a spring ??????????
I also checked everything I have, and no pictures I have show that bracket.
We are talking about your 72 correct?
