Old 12-05-2013, 10:35 AM
Was that with a Holley 4 barrel? Im still gonna get it on my buddy's dyno and tweak it when I get about 500 miles
Old 12-05-2013, 11:00 AM
It was a stock rebuilt 350, small cam, rebuilt 4bbl QJet, stock intake manifold, mid length headers, 2.5 mandrel bent duals. TH350, 2000 RPM converter, factory 12 bolt rear with 2.73 gears. Not to mention it was over 4000lbs.
Old 12-07-2013, 03:24 PM
I got the wiper trans yesterday. Thanks Ray. Going to try and get them installed tomorrow. Rain has moved back in.
Cars running great. Been going everywhere with it. Its been my daily driver. Thanks again yall for all the help, advice, info, parts.
Old 12-08-2013, 05:05 PM
Got all the wiper parts in today. Just need to wire it up.
Also got my new shocks in the rear. Then removed the front coils and cut 2 coils off. It dropped it quite a bit. But it handles better than ever. Slightly harsh on big potholes/bumps. Nothing rubs. But ground to header clearance is just a couple inches. Need to go slow over speed bumps!
Old 12-08-2013, 05:29 PM
Need wiper motor wiring help. What I have is not coinciding with what my diagram has. Or so I think?
Old 12-08-2013, 07:28 PM
Don't forget those coils will sag with age. It's going to be real low.
Old 12-09-2013, 06:17 PM
Default 72 Driver NorthCarolina UNDER CONSTRUCTION
You would figure. But the rear are original and are still holding strong! We will see how long it takes to grind down my header flanges
Got the wipers installed, wired and working !!!! Thanks again Ray
Now what I need is a picture of the windshield washer squirter location on a cowl induction hood. Who has some good photos for this big dummy?
Old 12-09-2013, 06:58 PM
http://www.chevelleforum.org/showpos...postcount=1354
You can see mine here, might have to zoom in to see exactly where they are. I currently have a domed hood like on your car.
Old 12-09-2013, 09:03 PM
Your welcome, also the squirters for a cowl hood and a flat hood are not the same. Make sure you have the correct ones. The cowl hoods squirters are longer.
http://www.ebay.com/itm/70-71-72-CHE...90537855662%26
Old 12-10-2013, 05:48 PM
Did a review of this all the post in this thread today. Wow, I forgot all the work you have done to get it to this point. You should be very proud of all the work you have accomplished on this build. My hats off to you.
