Old 03-02-2010, 05:18 PM
Default Thinking about 18's
I sort of like the torq thrust M rims. Was thinking about 18's all the way around. Would like to stuff as much tire out back as possible. What widths do you think ?
Old 03-02-2010, 08:24 PM
'72, correct? Are the rear lips rolled or trimmed? Rear suspension stock?
With careful measurements, you can fit a 11" wide rim with a 315 if your suspension is tight enough to not have any lateral axle movement, and the lips are rolled.
10" with a 295 is a little easier to accomplish.
Old 03-03-2010, 04:20 AM
Rear suspension is
Hotchkis 1 inch lowering coils
Bilstein shocks
UMI lower arms
UMI adjustable uppers arms
UMI control arm braces
UMI 1 inch solid sway bar
Front is
stock a arms
new ball joints
rebuilt front end kit
Bilsteins
Hitchkis 1 inch lower springs
Considering a sway bar up front and a new quick ratio steering box.
The lips of the fenders are not rolled.
What would you suggest ? Thanks
Old 03-11-2010, 05:23 AM
Would 18X10 for the back and 18X8 work up front ? If so how much rubber can be fitted to them ? Thanks
Old 03-13-2010, 12:30 PM
What back spacing would I need to run 18X10's in out back ?
Old 03-13-2010, 04:05 PM
5.5" would center a 10" rim with a rolled lip...
A lot of guys run 11" rims with 6 to 6.25" backspace, so you could gain some room by running around 6" if you don't want to roll the lips.
Old 03-16-2010, 04:43 PM
Did you get them? Any pictures?
Old 08-27-2010, 12:21 PM
Warputer's Avatar
Warputer Warputer is offline
Any pics Grumpy?
Chris
69 4-Door Malibu
Old 08-27-2010, 01:52 PM
Ms Grumpys got plenty of pics. Show em Ms Grumpy.
Old 08-27-2010, 07:10 PM
Rattler's Avatar
Rattler Rattler is offline
Did you ever get the 18's Grumpy?
I just found this on craigslist. One hell of a deal for a complete package!
http://phoenix.craigslist.org/evl/pts/1921980197.html
1964 Malibu SS, now a LS1 and T56, Back halfed, rollbar, narrowed 9 inch, 4.11 gears and 31x16x15 Mickey SSR's on Weld wheels.
