Go Back   Chevrolet Chevelle Forums > Chevrolet Chevelle Garage > Chevelle Maintenance
Old 10-07-2015, 07:19 PM
Chris69Chevell's Avatar
Chris69Chevell Chris69Chevell is offline
Default Rear Suspension Question?
Hey Guys I am getting ready to replace all my rear suspension on my 69 Chevelle.........springs, shocks, control arms etc.
Is there a certain order that I should follow when swapping out my suspension parts? Mods please move if I posted in the wrong forum.
Thanks!
Old 10-07-2015, 08:56 PM
I would start with control arms as they will be your biggest pain in the but, I had to have mine cut out in pcs as they were so bad that I could not get the bolt out. I would do it why you have the tank out as it will be easier for the upper control arms on the diff.
Old 10-07-2015, 11:13 PM
Just don't torque down the bolts on the control arms until you get all the weight on them.
Old 10-08-2015, 09:43 PM
Don't neglect to replace the bushings in the rear axle housing. They are a bear to remove, but well worth the effort.
Old 10-09-2015, 07:19 AM
Yes, they are a lot of fun. I would do one set of control arms at a time. That will help keep the axle somewhat in place. I still needed ratchet straps to pull mine into place when I replaced control arms.
Replace control arms, remove shocks, r&r springs then install new shocks.
Old 11-04-2015, 06:09 PM
Yea I had to use a ratchet strap too.....
Thanks for the help!
Old 11-04-2015, 07:41 PM
Don't forget to replace the tennis balls with a quality ball
Old 10-11-2019, 03:04 AM
dconnor dconnor is offline
Don't forget to replace the bushings and ball joints also.
Old 10-12-2019, 07:50 AM
pitts64 pitts64 is offline
Wow, tennis balls, haha....
Old 10-12-2019, 07:56 AM
I used the Spohn Del Sphere control arms. They are adjustable and the Del Sphere Spherical bushing looks massive and should be strong..
Having a four wheel alignment along with setting the rear end up at its optimum angle is so worthwhile..
Name:	Exhaust off set 2.jpg
ID:	4399   Click image for larger version
Name:	rear end 7.jpg
ID:	4400   Click image for larger version
Name:	Spohn drivers.jpg
