Old 06-23-2011, 03:16 PM
classic's Avatar
classic classic is offline
Default Strange problem...
Howdy all - It's been awhile! I am experiencing a strange or odd occurance with my '65 Malibu. I believe it to be electrical and maybe someone else has had this same problem.... I am running a DUI 50,000 volt HEI distributor and coil with a Summit CD Ignition Box for starters. So, I have noticed that after the car is running awhile and warmed up, maybe a half hour+ I start to notice an electrical noise like a buzz that fluccuates with the RPM. At idle you can hardly notice it but the higher the RPM the more distinct the buzz becomes. The strange thing is this... periodically the car will just shut down just like you reached down and turned the key off. No popping or running ruff, just dies. It happened to me yesterday and I coasted over to the center lane put it in park and it started right back up again and I had no other issues the rest of the way home. I am first think the coil but wondering if it could be the ignition box making the electrical noise and shutting down. Anybody else ever have a problem similar to this? I would appreciate any ideas or feedback.
Thanks,
Greg
Greg
1965 Chevelle Malibu
383 Stroker w/457hp
Old 06-24-2011, 06:38 AM
Not familiar with the setup you have. You can narrow down the source of the buzzing to either the coil or ignition box? I've had coils open up when hot and shut off the car. After cooling down car would start right up.
Old 06-24-2011, 01:44 PM
classic's Avatar
Thanks Hank - I have also experienced that same thing with the exterior mounted coils once the cooling fluid heats up the coil overheats and shuts down the car. That is the main reason I was thinking coil but the noise/buzz is what's throwing me. It's like RF noise like engine noise you get through your radio on AM without the filter... I'll shotgun the coil as it's cheaper but don't feel like spending the money on the ignition box if that's not the problem. Greg
Greg
383 Stroker w/457hp
