Old 12-31-2014, 07:28 AM
Pyasher Pyasher is offline
Default Intake Manifold Question
I have a 1967 327 - 300 using an Edelbrock performer aluminum intake.
The engine was rebuilt in 2006 and the block was decked.
I have been going through intake gaskets every few years - an internal vacuum leak.
Any thoughts on what the best gasket is to seal the leak and any other advice.
A friend said since the block was decked I may need to take a few thousands off the intake?
Thanks in advance for sharing your knowledge.
Old 12-31-2014, 09:18 AM
What gasket have you been using and having issues with?
Edelbrock recommends the Edelbrock #7201 gasket...which is .060" thick. Same as a FelPro 1205.
Old 12-31-2014, 09:22 AM
Don't machine the intake.
Old 12-31-2014, 09:33 AM
Most gasket mfgs say not to use sealer..
But I use permatex aviation gasket sealer.
The brown brush on kind in the jar...not the tubes.
I have never had a leak.
Old 12-31-2014, 09:45 AM
I do the same...on the head side.
Old 12-31-2014, 09:47 AM
And if the block has been decked THAT much, there are thicker (.120") intake gaskets available.
Without any gasket, is the intake resting on the "China Wall"?
Old 12-31-2014, 09:51 AM
Bill - I used a FelPro last time which was about 2 years ago.
I may try the Edelbrock one this time ( 3rd gasket)
Any specific reason why I should not machine the intake?
I just want it to run well - it has not been a major issue - sometimes it will idle a little rough and if I drive for a long time and get t hot when I stop for gas it will whistle for a minute or so on start-up.
Old 12-31-2014, 09:54 AM
Mestorod - I will try permatext aviation sealer this time - I have been using the RTV sealer in t
the tubes.
Old 12-31-2014, 09:59 AM
Bill,
It appears to seat just fine.
Who makes the thicker gasket?
My thought is to use the thickest gasket - the aviation sealer and some ARP bolts this time...
Your thoughts appreciated...
Old 12-31-2014, 10:32 AM
Mr. Gasket #106 is the closest port size to the Edl-1205 but is .120" thick.
Will work fine...
http://www.summitracing.com/ga/parts/mrg-106/overview/
