Old 02-18-2017, 09:17 PM
2008srx 2008srx is offline
Default another fuel gauge issue
first post for me, put in new gauge on a '69, and new sending unit. Fuel gauge reads below empty, When i disconnect sending wire in trunk, gauge go's to like 1/4 full only. when i ground the wire, it go's to way past empty. Anyone have any ideas? thanks
Old 02-19-2017, 12:55 AM
Is the ground wire good not dirty?
Old 02-19-2017, 10:38 AM
yes, tank and ground wire are new. just did an ohm check from ground wire to connector in trunk. only got a reading of 1.4 with 4 gals of gas, thinking it should have been like 18? i saw some posts where the sending unit is grounding out internally even though brand new?
Old 02-19-2017, 11:46 AM
It is grounded to the pickup unit that slides into the tank. And that is grounded to the body. So another check is body to battery. Is that grounded?. My car had 3 factory and has 6 now, I tend to be overkill on that stuff.
Old 02-19-2017, 11:02 AM
At empty it read around 2 ohms, half full at 40, and full around 80 to 84 ohms. Did you do a ohms check of the sending unit before you put it on? Also if you do a search on here on fuel gauge there several right up about it
